Quote: Quikshft your grain looks great . What method did you end up using for putting in the grain?
I used/am using a very high tech tool for this work...a broken off hacksaw blade. I just ground the end to leave one complete tooth exposed. I also ground the sides of the blade to make the tooth a little bit narrower so the cuts weren't un-naturally large. Actually now, and a lesson here from experience, I should have used two different blades to get a little bit of dis-uniformity to the width of the grain cuts. Still, I'm satisfied and unless I get a little too picky I will probably leave it as is.
