Unlike the rimblow which has a tape stripe, the 68-70 A and B body woodgrain wheels used a stainless steel band on the inner and outer perimeter of the rim. If it gets scratched, it can be sanded out with 400 grit sandpaper and will look like new again. Also, with it being stainless steel, you don't have to worry about it rusting or tarnishing so you don't have to clear over it unless that's just what you want to do. I like the bands slightly exposed as well.
Now, to keep the DIY guys motivated, here's before and after shots of a 70 B body woodgrain we recently had in the shop.
Before
