Quote: good info, like they say..the wheel is in your hands and face every time u are in the car...the hardest part will be the electrical switch installation and the wire attachment...spend that money on buying a switch and try to install it and ruin it...and u will end up buying another till u get it right.....at 125.00 a pop it will cost u alot to practice....but good luck it's a nice winter project...I tried, ended up sending it out....happy with both wheels from different vendors....had to compare...
usually most used blowrims have had a meltdown at sometime in their life, and the switch, or what's left of it fuses with the plastic rim, or distorts the insert, so it takes a little time to clean out and "square" up or rebuild the inner groove to recieve the switch
