Not sure if this topic was ever put to rest about the so called "pins" in a collapsible steering shaft but thought it would be good to see some pictures of one I had to repair today. The first picture shows bent shafts I received that could not be saved from 2 different columns. Luckily the bottom of one and the top of the other were okay so I could make a good one from 2. Jules
