Re: FYI Steering shaft dissection101
[Re: gygeneral]
#55518
03/30/08 09:46 PM
03/30/08 09:46 PM
Posts: 18,423 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
This is great Jules, I've never taken one apart. But I'm wondering is there a coresponding recessed cavity in the female shaft? Norm
Not as I recall. The excess that flows out the holes acts as a shear point. If there was to much teflon in a larger cavity it would not shear as designed. Even using epoxy or ant repair for that matter is a gray area libility wise. But what is one to do when parts are so hard to find.
[Re: JulesdaWiperman]
#55522
03/31/08 09:31 AM
03/31/08 09:31 AM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
Thanks for the info. I'm currently going from manual steering to power in my 1971 Challenger. From what you see will it be possible to collapse my longer manual steering shaft by hammering the shaft in and make it work on a power steering box?
#55523
03/31/08 09:54 AM
03/31/08 09:54 AM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I am not sure I would use epoxy either. I think it would bond the two halves together. What about the cast resin stuff that is liquid until hardens?
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
#55528
03/31/08 01:35 PM
03/31/08 01:35 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
" I hear of others bolting, riviting, and even welding the shafts togeather." Thanks for the input guys. I'll stick to my method for now. Jules
my father had to be cut out of a 65 mustang that he was pinned in when he tangled with a 54 olds , it wasn't pretty .
