Re: FYI Steering shaft dissection101
[Re: 375inStroke]
#55551
06/09/08 02:14 PM
06/09/08 02:14 PM
Posts: 18,427 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Why is so much effort being spent in "repairing" the shafts. Where are they going to go? You, Jules, said you needed a sledge to remove the shafts from each other. You are restoring them, so I see why you are doing it, but for the rest of us, who will ever see it? The upper shaft is held in at top, and the lower shaft is held in at the steering box. The only force on them is in rotation.
There is a right and wrong way to restore or repair a shaft. Doing it right will have several benefits. 1- Its safe. 2- It wont rattle. 3- Its done correct and not hacked up.
