Quote: if you are using the pad style motor mounts you can shim the mount. schumacher headers actually come with them, maybe they can sell you just the shims.
Yes they sell the shims separately , I bought a set a couple years ago to make up the difference for what they were selling as a factory big block A body replacement mount that was thinner than the stock mount .
