Sometimes you have no choice but to use the Borsen joint, which is actually better than the stock knuckle,...if a stock look is what your after, then your going to have to play with the motor mounts, some shimming might help, loosen the box to see if you can "move" it some, or break out the dremel, and elongate the holes to move the box over, or remove and "dimple" the header tube, I've used a peice of oak dowel to place on the offending tube, then hammered the oak, puts a nice "dimple" in the tube without busting up the coating, do this with the header removed and supported
