It sometimes helps if you disengage clutch with prybar etc, if it's that close to going in, just incase the clutch is not quite centered.
I second this , just because you THINK it's aligned properly it still may not be , I've done this many times before . Also it might be easier to install some long 7/16 bolts with the heads cut off in the top two trans mounting holes to help guide it straight in .
I third this. Happened to me. Once I loosened the pressure plate bolts slightly it slid right in.
