I am a big fan of a proper pattern, i hate noise from the rear and the vibration it brings with it.
I see the drive and coast are now on the same part of the gear so you are real close. Can you have someone with a lot of pressure hold a prybar between the case and the spool while your turning it so it cleans up the lead and gives us a better look.
