Yes a pump gas car. Im not losing the T-ram sorry. Its staying. I know it will perform better on the street without it. Gas milage will be better without it. But I like it. I think I decided on
440 .060 over
stock rods ARP bolts
Speed Pro Dome pistons for about a 10.3 comp
Comp Cams XE285HL cam
440 source stealth heads OOTB
2x600 Holley Weiand Tunnel Ram
Dana with the 4.10s 29 inch tire
727 with a 3200 stall.
Now I just need ignition what do you guys recommend?
Not necessarily, i got better gas mileage & low speed responce from my TR, started better after sitting a week or so, better idle too, so i would keep the TR.
SO a guy that has experience with running one on the street. How do you think that build will work with the T-Ram?
