Yes a pump gas car. Im not losing the T-ram sorry. Its staying. I know it will perform better on the street without it. Gas milage will be better without it. But I like it. I think I decided on
440 .060 over stock rods ARP bolts Speed Pro Dome pistons for about a 10.3 comp Comp Cams XE285HL cam 440 source stealth heads OOTB 2x600 Holley Weiand Tunnel Ram Dana with the 4.10s 29 inch tire 727 with a 3200 stall.
Now I just need ignition what do you guys recommend?
