The bog is probably not enough fuel right off, is the accelerator pump linkage adjusted so it shoots right when you touch the gas?
I noticed the springs on both carburetors are pretty weak, even though they were both new. The spring would collapse before it squirted fuel. I was thinking of making a sleeve for it so it would squirt as soon as the pedal was touched.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
