Quote: cowl hood gond BAD.....this may be an example of why people dont like them...
I actually had it lowered about two inches. The guy that did the hood screwed up. It was not supposed to keep getting taller as it went back.
However, when you guys can figure out how to put a Predator headed 654 with a sheet T/R and two fours under the hood without it being that tall, you let me know. We are not allowed forward facing scoop for the most part.
Why is there a rule for rear facing scoops ONLY. How is such a goofy rule even created...must be NHRA. Rule was probally created by the same guy that created the new points system for the Pro's??
