Thanks, but I know. Surface rust and leftover foam gack. I was inside there welding, remember, so I got a good look at it.
I will be handling that when I pull the windshield and dash. I have a black dash without the holes for the fake woodgrain and a good pad that I will be swapping in. I will be installing an 18 watt Marshall tube amp IN the dashboard. I will handle the cowl then.
When I ditch the rear seat I will be installing a carpeted shelf for my dog that will unlatch and double as a Stratocaster or Explorer case.
