Just got done for the night. Mainly doing lots of little unimpressive stuff right now. Grinding paint from around the excess holes in my engine bay where smog equipment and A/C stuff used to mount, cut out part of the A/C firewall and my patch panel from the spare firewall, ground all the green paint off of it, stuff like that in the engine bay.
Been degreasing and semi-glossing brackets.
Got the Magnum to LA bypass hose puzzle solved, figured out that an LA water neck is too big and I meed one from a SB Ford. Modified the 14 x 3 air cleaner to fit over my new Demon carb and make my old throttle/kickdown stuff work.
My poly front suspension arrived yesterday. On the workday eves I only get a couple hours in, Last week was vacation, remember. More updates this weekend.
