All you do is put the bar so one arm & the main length of the bar sit in the throat of the press, I used a piece of 1/2" flat stock as an adapter between the ram & the "V" created by the bar & simply press... The arm will bend, thats how they bent it it the first place... It's spring steel so it tries to spring back but the press will excede the springs ability & it will bend... I took a measurement before I started then when one arm is in 3/4" flip the bar & do it again...
Good to know!
