OK, I got the Dr Diff kit in and installed. Nice pieces.
One problem now. The rear sway bar doesn't line up any longer. The end links are at too much of an extreme angle. And even if I was to keep the Ebody bar I imagine it would now be in the way of a wide tire.
What are my options?? Is there a B-body rear bar that will bolt in and line up??
Can I section the bar, remove 2 inches out of the middle and weld it back together with a steel tube in the middle?
Let us know what you come up with the sway bar and please post pics of the rear end and rims/tires under your car.
I'm going to be doing the B body rear swap into the wife's Challenger soon.
I already have Dr. Diff's kit and plan to try to stuff a 15x10 wheel under the car with 5.75" backspacing using a 1/4" wheel spacer.
Tires are going to be 325/50-15 BFG Drag radials.
