First and foremost, you should check to make sure you either have a 4 speed crank, or have it drilled to accept an input shaft, and measure your input shaft hole depth to make sure the shaft will go all the way into the crank without bottoming out. We were fine.
Our assembler brought his own pilot shaft to help with alignment throughout the assembly process. Another important point is having to preassemble everything to make sure it will all work together. This was already done by me during the week, just so there were no unseen surprises. I also chased all of the thread holes to ensure ease of assembly..
Our first major task was to dial in the bellhousing to block. One wants to make sure it centers the tranny to the crank centerline as possible. without it close ,the engine will slowly eat itself to death, and bad vibrations will tell the tale of it being off. We used new dowel pins to get a baseline of where our bell to block lined up. we cleaned them up with emory and a drill press.
First off, clean the flywheel, and bolt it onto the crank, leaving one bolt out for the magnetic dial indicator assembly.
Next, clean each surface that will be mated to each other. You need nice, clean surfaces to work with.
