I think I have everything ready to go into the car this weekend. I was delayed because of having to order some new stuff and because of family.
The RobbMac starter was just a tiny bit too long and interfered with the #6 tube of the tti headers. This starter is 8" long I believe. I bought a Denso starter from Mancini which is 6 1/2" long and it fit fine. There is still not a lot of room but the headers will bolt up on the driver side. I had to grind off one nipple on the passenger side of the bellhousing to make the header fit there but that was easy. I am using an 11" bellhousing as stated above with 11" McLeod diaphram clutch. Everything works on the garage floor so I think I am good for installation.
