No stack injector will make the power of a tunnel ram. BTDT long ago.
I guess I will find out lol.
Blusmbl I don't plan to run an IAC, I will drill all the runners for a vacuum line in order to make a small chamber for a common map signal. I'll turn on timing control to help maintain an idle speed. I will only miss it on cold starts most likely.
