Originally Posted by justinp61
If it ran at 6.65 pounds per cube, it would weigh right at 2100 pounds with a 314" engine. At 160 mph the Moroso calculator puts it at 660 hp and about 685 for an E.T. of 8.41. Still pretty impressive number for a mill that small IMHO.
A friend had some cast iron W2 heads ported for his 417" 340 based street motor. Chad Speier out in Hays, Kansas did them and is a wizard with heads. This thing puts out north of 600 with a single 4 intake! Very impressive in that it's a 3,200 lbs. full interior all steel street car that runs 10.40's with mostly off the shelf parts and some massaging. shocked
'63 Dodge 330
11.19 @ 121 mph
Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
