Quote:I would say forget the eddys unless your car is setup on kill. It would take a very well layed out chassis to run the #'s you want with eddys.cars are never as fast as you think they are going to be.I would suggest the Indy firstthen a W2 or W5 if you can find themor a Large port commando would be good also.Good luck
