Originally Posted by NITROUSN
Originally Posted by Cab_Burge
Originally Posted by TJP
He still needs to check his current draw and charging capacity beer
iagree scope
I installed one large aftermarket electric fan on a drag only car years ago and found that it would draw 70+ amps on startup initially shock
To much amp draw can melt overloaded, to small, wires real quickly puke tsk
That is why the load for these should never be off the alternator stud. Worse on older cars with inductive ammeters and failure prone bulkhead connectors. Alternator should be wired with protection direct to the battery or a buss connector. All loads should be off that point and correctly set up with relays and fuses.
With ammeter, all loads must be sourced from alt side of the charging network, never from batt
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
