I have ladder bars that are up on the top most hole. The rear shocks are DA Afco modified by Menser. IFIRC, I have 110 lbs springs in the back. I can't get any more travel due to the shock length.
My next move is tighten up the fronts 6 clicks. I will continue to tighten up as needed.
