You could clean a drain pan, clean the trans and save the fluid to reuse. Other than that, I know of nothing.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
