Re: It's a turd, what to look for?
[Re: parksr5]
#3086767
10/17/22 10:06 AM
10/17/22 10:06 AM
Posts: 14,494 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’d say step one should def be make sure timing is correct, you’re getting wot, etc....... the basics.
Pull all plugs and do a cranking compression test on all cyls.
If it all checks out good, head to the chassis dyno for a few pulls.
When it had that valve float at 5500, it had a different intake on it, correct? What was the speed then?
I’ll just throw this out there as another possibility ........ the converter might be going away.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
Entire Thread
parksr5
10/17/22 12:19 AM
polyspheric
10/17/22 12:28 AM
Blusmbl
10/17/22 12:30 AM
parksr5
10/17/22 12:55 AM
GomangoCuda
10/17/22 02:39 AM
Locomotion
10/17/22 12:45 AM
parksr5
10/17/22 01:04 AM
parksr5
10/17/22 01:07 AM
CMcAllister
10/17/22 01:24 AM
parksr5
10/17/22 01:33 AM
parksr5
10/17/22 01:39 AM
Cab_Burge
10/17/22 01:51 AM
madscientist
10/17/22 01:52 AM
parksr5
10/17/22 02:46 AM
slantzilla
10/17/22 03:01 AM
parksr5
10/17/22 03:16 AM
CSK
10/17/22 03:28 AM
lewtot184
10/17/22 11:18 AM
Blusmbl
10/17/22 11:46 AM
BSB67
10/21/22 02:15 AM
lewtot184
10/21/22 12:54 PM
Cab_Burge
10/21/22 05:51 PM
fast68plymouth
10/23/22 07:26 PM
parksr5
10/24/22 12:56 AM
fast68plymouth
10/24/22 02:08 PM
GTX MATT
10/24/22 02:53 PM
parksr5
10/24/22 08:30 PM
krautrock
10/24/22 08:47 PM
parksr5
10/24/22 09:11 PM
lewtot184
10/24/22 08:48 PM
parksr5
10/24/22 09:14 PM
LA360
10/24/22 10:50 PM
JAKE68
10/25/22 12:23 PM
GTX MATT
10/25/22 01:07 PM
moparx
10/25/22 06:19 PM
JohnRR
10/26/22 03:22 PM
BSB67
10/27/22 02:57 AM
John Brown
10/27/22 04:23 AM
JohnRR
10/26/22 03:14 PM
roadrunner2
10/26/22 04:15 PM
lewtot184
10/27/22 11:40 AM
lewtot184
10/25/22 12:13 PM
an8sec70cuda
10/25/22 12:21 PM
Cab_Burge
10/26/22 01:46 AM
lewtot184
10/26/22 02:01 PM
roadrunner2
10/26/22 02:38 PM
fast68plymouth
10/24/22 09:06 PM
BSB67
10/26/22 12:20 AM
madscientist
10/17/22 01:56 PM
fast68plymouth
10/17/22 02:06 PM
CMcAllister
10/17/22 02:17 PM
krautrock
10/17/22 02:03 PM
340Cuda
10/17/22 04:21 PM
Torquemonster440
10/17/22 03:25 PM
parksr5
10/17/22 04:17 PM
fast68plymouth
10/17/22 04:36 PM
dvw
10/17/22 05:06 PM
CMcAllister
10/17/22 05:47 PM
HotRodDave
10/17/22 05:06 PM
