Anyone know how the bowl vent is supposed to open? My linkage does not engage the vent lever. Pictures I’ve found on line look the same as mine.
Your vent valve looks "pushed in". It should stick up like in some of the other pics. As mentioned, it vents the fuel bowl and is opened only at idle. If your "pintle" (part of valve that sticks up) was UP, that would move the rod your looking at closer to the throttle lever that pushes it. After that, bend the rod as needed. It is supposed to open and allow fuel vapors (center carb only) to go to the charcoal canister. The older carbs just had a vent hole. I'm not sure exactly why
