Checking Bowl Vent Valve Clearance To check the bowl vent valve clearance adjustment, proceed as follows: (1) With the throttle valves at curb idle, it should be possible to insert a .015 in. gauge between bowl vent valve plunger stem and operating rod, (Fig. 26). (2) If an adjustment is necessary, bend rod to change arc of contact with throttle lever
