Carbs built after Jan 1, 1970 all generally have the same vent as the OP picture. It is correct that it was a design made for emissions control. Previous to Jan 1, they were not required. I’m sure it was an EPA thing. As to why it’s not working as it should direct from Holley, is a mystery. I restore six pack carbs now that Bill O has passed and have many carbs in the works right now. I’ve got some original carbs that are off of my AAR so I’ll inspect them when I go to the shop. I’ve done multiple sets of the early style bowl lately but I have a set in progress with the emission bowl so maybe I can check it out today. I did have a problem with the last emission bowl set and I used a new Holley vent arm. I had to bend it quite a bit to get it in the proper specs. I did not try and compare an original arm. Looks like I may have to do that. Be careful in bending that rod. It is made out of hard material and does not bend without a lot of force. You can mar the plating very easily, though.
From the FSM
Checking Bowl Vent Valve Clearance
To check the bowl vent valve clearance
adjustment, proceed as follows:
(1) With the throttle valves at curb idle, it should
be possible to insert a .015 in. gauge between bowl
vent valve plunger stem and operating rod, (Fig.
26).
(2) If an adjustment is necessary, bend rod to
change arc of contact with throttle lever
