Originally Posted by gregsdart
I have been considering a move to a 580 cu in 572-13 motor with 15/1 compression on methanol. Expected power would be over 1050 hp at 7400 rpm. Torque will be 800 + somewhere. Can stock input and output shafts handle this kind of power? Launch will be about 4800 rpm or less, with a converter that will flash to 6300 behind this beast. Tires are 10.5 x 33 hoosiers so shock from launch shouldn't be too bad. Tell me your experiences of stock shaft failures so i can figure out whether i want to try this.
I can say, I have never pushed one that hard....We have made 850hp and had no issues....We build them per what A&A recommends for parts for that level. At your level, a glide will probably be cheaper and hold up better. The only thing is with a glide, it tends to take a couple tries to get the convertor where you want it. Much fussier without that extra gear to get you moving. ...
Now I have a friend pushing a 727 to 1200hp in a blown application, and it can be done, but he seems to find the limits of everything, and that is where he cracked a case....I don't think there was anything else that failed on him.
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
