Originally Posted by a12rag
Well here is something on the desalination front :
https://www.designboom.com/technolo...n-unit-generates-clean-water-04-29-2022/
Can be solar powered !!! . . . there it is, time to ramp up the scale and start sucking up the pacific for the parched California areas . . .
Excellent idea. This will piss off the environmentalists though....You tell them that using sea water will offset any rise in ocean levels and watch their heads explode!
