Originally Posted by '72CudaRacer
A small cut off wheel works well. Clean cut and straight. Or a chop saw works good, but kinda over kill.
Brian
I think you missed the issue.
1) chop hose off.
2) slide female end over hose.
3) trim back nylon braid <~~~issue
4) expand steel braid.
5) slip ferrule over inner hose.
6) poke male end into hose.
7) screw pieces together.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
