just had a look in my dyno folder . Here's a couple of runs .
1 is modman no filler or spacer
2 is modman with filler with/without carb spacer .
The only time a really raced it was without filler if i remember correctly .
This might help Dizuster as well .
Tex
PS dont worry about HP curve , was always the same no matter what induction or ET car ran . It seemed to hit the converter stall speed and show no more
Thank you Tex! It is for Diz. I'm not sure how to read these charts, it appears the intake with NO mods made the most power on your combo. Can you spell out the results in just text? i.e.- "The divider added 25ft lbs of torq across the board"
