Originally Posted by Montclaire
Originally Posted by bee1971
With your 284-484 Cam what’s your vacuum at idle ? Probably pretty low I would guess
Vac was around 8 or 9 at idle.
Surprised it’s that high honestly
Anyways so stick with the 5" factory orange springs or drop down to the yellow 4"
Start with the .068 X .052 metering rods , verify your float level and drop and go from there
What’s your plugs look like in idle/cruise circuit
Have you pulled them
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
