My '68 RR is running the AVS2 650 manual choke on its basically stock 383.
Only tuning change I've made is going 2 steps leaner (cruise) on the rods using the Eddy tuning kit.
4-speed & 3.23s if that matters.
Runs way better than its #s carb, which I should take to Scott Smith for investigation of someone's previous rebuild.
