I see that milodon lists their part number 32006 windage tray for this oil pan. Will the stock tray not work? Also, is there an issue with not installing the bracket for the pickup tube underneath the main cap bolt? I'm very skeptical on loosening the bolt and installing the bracket. I'll have just under a 1/4" less contact on the main cap bolt with the bracket underneath.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
