i would look at and buy the same size ET Street Bias ply as the slicks you mentioned
Are the tires you mention,295/65/15, radials or bias ply?
I ran the M/T ET Street 325x60x15 ET Street Radials and the same size ET Street bias ply and the radials were faster on a good track but not worth a hoot on fair or bad track or on fair street
Once the radials would start to spin I had to let off for them to recover
The same size ET Streets might spin a 1/4 to 3/4 turn on the hit but hook and stay hooked up after that on bad streets and roads
I ran both 10 and 12 inch wide rims and used 18 to 20 lbs. on the radials and from 9.0 to 12.0 on the bias ply tires depending on the track conditions to get them hooked up and stay hooked up
I ran both tubeless also
