Every car will be different but we run 18 psi in our drag radials. Shock settings with the Calvert/Rancho's was always full stiff @ #9. Fronts at 90/10. Best of 1.36 60 ft.
With Vikings running N/A we are doing 12 Compression and 6 Rebound on the rear. Not much of a chance to test with the Vikings with nitrous but it is doing a wheelie and then unloading and spinning with them. Going to try going to the 70/30 to slow down the extension. Ultimately it needs Vikings on the front, too.
'63 Dodge 330 11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs. 10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
