Re: 572-13 FLOW NUMBERS
[Re: Old School]
#295854
04/22/09 12:19 PM
04/22/09 12:19 PM
Quicktree
MUST NOT BE DOING SOMETHING RIGHT WITH THE BENCH
All caps indicates the sender is SHOUTING I have found that the flow numbers are easily influenced by the shape of the flow device(hand formed clay, hard mandrel or what ever or none) or lack of a flow mandrell on the intake port and a pipe on the exhuast port. Not all flow benches flow the same on the same head and port, some benches are happy and some are not Not all shops write the actual flow numbers down exactly the way the head flowed, especailly if it is the work they did on them being flowed, some other shops may say the heads flow less than they did on thier bench so they can ("work on them") to make them flow better the second time they "flow them"
No I am not shouting,Thats not my style, I don't know how to type well and I'm half blind so it's hard for me to see these little letters. But anyway, the heads are untouched CNC'D from Indy. I am not going to have the shop do any work on them, I was just having them checked. How can they be so far off from what Indy claims? We're putting a call into Indy today to make sure we are flowing these properly. Thanks for your input. I'll post what Indy says after we talk.
good luck with getting anything from Indy, let us know how that works out for you.?
