You were talking about putting a shaft kit in it, that would give you the instructions on lining up the cage to the manual valve, and how to measure the pressure regulator. The old b@m and trans go kits came with a template to set it. You could either find the instructions online or I could send you a pic of the template later.
I don't recall mentioning a shift kit in any of my threads... I'm pretty sure I won't be getting a new shift kit. I just need to make sure this one's adjusted, thanks!
