He did mine and it was perfect. Have you talked to him on the problem.
Left him a msg on sunday 6/13.
Did he convert your old wedge K-Frame? If you still have your old you could level the K and measure in degrees the gear box mounting and compare it to the Hemi one in the car. That would give you an idea. If every component was on your old wedge k frame and fit fine it has to be in the box mount. How does the steering shaft line up? You should see a severe angle there also.
