For a 360-2 van pulling heavy loads I would go to a 12" converter...less slippage, less heat buildup.
The Dacco has the correct external weight and uses the stock factory flexplate but you'll have change from the 11" flexplate.
Hmmm, didn't know I could go with a bigger converter...
Had I known I would've expanded my search criteria...
I actually just ordered the Torco 764HD with a stall speed of 1800-2100 for $195 shipped! They have a good reputation and for the price I think it was a good choice.
If I had a little more patience I would've probably searched around a bit more but...
I appreciate the info!
