Hey Jim,
If I may make a suggestion:
When done with each section, it might be a good idea to ask one of the moderators to move the threads to the
Members Projects Area so the pictures don't get lost.
Brilliant !
Both Part 1 and Part 2 are not "done". I still need to buy pistons, etc. and I will update each "Part" when available.
Also, any questions about a post in each "Part" I can answer in the "Part". But this fall it would be helpful in the long term to have the pictures with the text for years.
I have been doing searches for many years, and I have experienced your issue.
Thank you sir.
Google images seems to be a better source for older images than the site itself (odd).
Ability to comment or question is perpetual in the projects area, wheras since the archive is basically locked, which is an advantage.
I made the mistake of moving more than one valuable, helpful thread to the archive back in my past days as a moderator,
and got yelled at ("Hey I wasn't done with it!") ....this will never happen in the projects area if it works as designed.
