Hello Andy , can you give a run down on the specs , HP & EFI components used . And any reason for going with that throttle body versus the 4500 super sniper . Different dist etc: I am wanting to change over to this set up & need info . Mine is drag only though , 700 HP auto . Thanks Gary
