Hi Cab,
I didn't think it made a difference what brand of block, except maybe wet sleeve blocks, those I know nothing about.
In fact I thought they get installed with some kind of lube, they are a press fit in the block but not a super tight press fit,
or so I thought.
I don't see how you could press them out since you can't get to the bottom edge of the sleeve.
