How is it normally done, block goes in an oven ?
How hot ?
How do you grab the sleeve to pull it out ?
Putting sleeves back in is different, I think, don't the sleeves get super cooled
and block stays at room temp ?
Which brand and type aluminum block? Race or street block?
Most aluminum race blocks, water cooled blocks, are design to have the sleeves replaced at the races with a sleeve puller, same thing I think on the newer billet race blocks with steel or iron sleeves
I'm not sure on the street aluminum blocks
