The length of the exposed adjuster changes the rocker ratio, as well as the geometry.
Why don't manufacturers show these dimensions, especially the "Delta" or difference angle between the 2 levers, and the fulcrum's distance away from a line through both lever ends?
Because you would buy rockers from someone else, who don't make it difficult to make a choice.
Trust me: engineering excellence yields to sales volume every time.
