Originally Posted by moparx
something that looks odd in your picture is the terminal ends.
it has to do with the space, or lack thereof, between the ears of the cable ends.
knowing a person only needs to tighten the terminals snugly so they don't rotate, i have found terminals that do not have at least 1/8" gap between the ears have a tendency to not contact the post surface entirely, allowing air space [however minutely] between the terminal and post to possibly create corrosion in the future.
also, the negative post looks to be sitting somewhat proud of the post top. using a set of battery terminal spreading pliers would help the fit of that.
not trying to nit pic, just observing a couple of things that have caused me corrosion issues over the years.
beer
Yes, I have to spread the negative more, I know, but thank you. I tried to split it open more with a flat screwdriver (all I have) but it wouldn't split more, and just would not go down any further on the new post. I was anxious to get it hooked up, so that was just for now, but I definitely wanted it lower. Thanks again. Larry
Facts are stubborn things.
