Yes, .141@106*x1.6=225.6, How do I use that number?
you don't use any lift numbers except for the lobe lift when doing rocker arm ratio verification, IE .420 lobe lift X 1.5 ratio =.630 minus the lash of .018 =.612 net lift at the valve at max lift. Same procedure on 1.6 ratio=.420X1.6=.672- lash. minus .018 lash =.654 net valve lift at the retainers
Your results may and probably will vary with the race valve springs in place with less than the best pushrods
![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
In your example of having .141 lobe lift at 106 degrees might mean you have calculated .2256 inch valve lift at 106 degrees, maybe not
